water level
Eric_15
Member Posts: 4
I just replaced my expansion tank. Thanks alot for the help. Now I have a another problem how do i know when my system is full.
Steam or hot water? If hot water, make up valve is left open all the time. If steam, there should be a water level mark on boiler jacket behind sight glass. If there isn't, usually half to two-thirds up the sight glass is fine. But maybe not. Best I can tell you.0 -
its a water system.Make up valve? Is that the valve releasing the house line to the boiler. That valve is before the pressure reducing valve, then there is a valve with a pipe going to the floor.And then into a tee which goes up to the expansion tank and then the air vent valve, the other way of the tee goes into the boiler.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 65 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
