PUMPING BOTH WAYS?
REFERING TO J SIEGENTHALERS ARTICAL APRIL 2004 PM MAGAZINE TITLED THE LONG WAY AROUND. DEALING WITH EXCESSIVLY LONG LOOPS. I CURRENTLY HAVE INSTALLED THIS TYPE OF SYSTEM, WHERE A HOME OWNER LAID THEIR OWN TUBING 1/2" HEPEX SERVING ONE ROOM 12" O.C. 1 1/2" GYPCRETE NO UNDER FLOOR INSULATION. IM ONLY TRYING TO CORRECT THIS ONE 650'LOOP, CURRENT RESULTS 20 DEG T AT FIRST START UP. HAS ANY ONE ELSE TRYED THIS METHOD? WHAT KIND OF RESULTS HAVE YOU SEEN? IM ALSO THINKING POSSIBLY SNOW MELT WITH THIS SYSTEM?
  • Weezbo
    Weezbo Member Posts: 6,231
    series pumping?
    seen pumps installed half way round the loop
    seen parallel and series
    push and pull...my thought would be to find the center cut it in two 32o+ loops on same zone call that good...less guess work
