Recommendation for thermostatic radiator vent valve?
Jeff_31
Jeff_31 Member Posts: 1
Does anyone have a recommendation for a thermostatic
radiator valve I can use (on the vent side of a radiator) for a single pipe steam system?
I've seen pictures of a danfoss
one which looks ok. Also any thoughts on where to
buy (in Central NJ or internet) greatly appreciated.
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    For a 1-pipe steam system,
    > thermostatic radiator valve I can use (on the
    > system? I've seen pictures of a danfoss one
    > to buy (in Central NJ or internet) greatly
    > appreciated.
  • BillW@honeywell
    We have the Y100P1001 which includes a 1/8 angle pattern valve body, a steam/air vent and you'll also need the T100A1028 actuator. You can find these at larger steam/hydronic-oriented distributors. Not all Honeywell distributors carry this product. They formerly were known as "Braukmann" valves, but now they are Honeywell.
    Use the Find A Contractor feature above, if you are a homeowner. There is no retail equivalent of this product.
  • J Collins
    J Collins Member Posts: 1
    Danfoss 1 Pipe System
    Jeff, Wallace Eannace Associates is the local representative for Danfoss Thermostatic Radiator Valves.
    Danfoss is a world-wide manufacturer for these valve with over millions of valves operating in buildings around the world. We would like you to contact us at 201 891-9550 (ask for customer service) for any questions you have on the technical operation of this valve and we can provide assistance for locating a local distributor in your area.
