Embedding Tubes in Sand .. on the main floor !?!
I have a customer that wants to have their tubing installed within sleepers on main floor level... embedded in sand.
Have done this type of install with both heat transfer plates & reflective foil, but never with sand.
The link given to me was... www.radiantcompany.com
I've sent them an EMail to get some data on this granular installation, but have received nothing to date.
HAve any Wallies ever tried this method or have an opinion on its validity.??
Thanks in advance,
Einsiedler
  • Carl PE
    Carl PE Member Posts: 203
    never tried it.
    seems like the sand would find it's way out sooner or later..
    please tell us you're not looking at an open system.
  • hr
    hr Member Posts: 6,106
    Skip the sand
    in addition to the points mentioned in this article, seems like an excellent place for ants to take up residency :)
    http://www.pmmag.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2379,116124,00.html
    hot rod
  • Dave_38
    Dave_38 Member Posts: 8
    Sand-
    is an insulator not a heat bank, anyone who has tried walking on a beach on a hot day will tell you how hot the sand is on your feet, dig down two inches and you will find cool sand, spend an evening in the desert and see how long the sand holds heat after sundown and you will know even more about it. Final point is this, IT DOES NOT WORK! I would also be some little bit worried about the weight of this project. Sounds to me a lot like somebodies dream child put on the internet.
  • Einsiedler_2
    Einsiedler_2 Member Posts: 93
    Thank you Gentlemen
    Excellent Article/Link !
    I will now spend my next efforts on this project, educating the customer.. wish me luck!!
    "Everything's better wet"
    Regards,
    Einsiedler
  • RoosterBoy
    RoosterBoy Member Posts: 459
    i could not agree with dave more dave your right man good point.
  • we did it once
    and it's the only job I ever did that never performed to expectations. Part of the home heated great. But both ends of the house ended up needing supplemental.
    We'll never use the method again.
  • jerry scharf_2
    jerry scharf_2 Member Posts: 414
    \"everything's better wet\"
    Actually, if you kept the sand saturated, it too might work better. :)
    jerry
  • Gary Myers_2
    Gary Myers_2 Member Posts: 2
    Sand Bed
    Here is a link to a fellow who used PEX in sand under a concrete floor - note that he WETTED the sand down as Jerry mentioned. The concrete had conventional radiant PEX in it as well, heated by an AquaStar or some such. The sand PEX was heated by solar collectors with the ability to shunt the heat away during the summer. It seems to be working well for him; note that you can read real time floor temps, outside / inside temps etc on his website:
    http://www.daycreek.com/dc/HTML/journal061100.htm
    Gary Myers
  • Einsiedler_2
    different app.
    thanks for the link.
    it appears that the application on the website is for a concrete floor (embedding tubes in sand under concrete)
    I'd still be nervous about using sand as thee thermal mass on a main or upper floor.
    Thanks,
    EIN
  • Marty_3
    Marty_3 Member Posts: 14
    Radiant sand
    I read an article written by John Siegenthaler in 'Plumbing and Mechanical' some time ago (year?) about this very subject. He proved with physics that this method is one to stay away from. Like Dave says, sand is an insulator, not a heat emitter.
