Convert Old Farm house from baseboard electric
Jeff Schmone
Member Posts: 2
I have a old (pre revolutionary war) home about 1,000 ft above sea level 60 miles north of New York City. It has baseboard electric heating and I'd like to switch to something else and am open to suggestions.
I'd like to avoid adding a new chimney, and there is less than perfect insulation and seal around doors and windows.
Any suggestions?
Any suggestions?
Sky's the limit
You can plan on spending alot of $ to convert to anything. Need more info,.etc. full basement?, any gas..prop. or nat gas ....???0 -
Jeff, the first thing I'd do
is beef up the insulation, weatherstripping and other improvements to the building's envelope. Then do a heat-loss based on these upgrades. The resulting system will be smaller than if you hadn't upgraded the envelope, so it will be less expensive to buy and operate.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
Propane gas is available, but no natural gas (unless there is a way to get it delivered similar to propane).
There is a basement which was dug out below the original house which was built on logs lying on the ground.0 -
Steamhead is absolutely right...
roof, windows, doors, insulation...tighten the building envelope first, then you can save both on the size of the equipment you install, and the operating costs as well. Oil? Natural Gas? Propane? Wood? Remember that the cost of energy is the third largest cost for a homeowner after taxes and mortgage. Think of your house as a system, and don't make the mistake of considering only your heating/cooling system in energy usage terms. Domestic hot water, refrigerators/freezers, ranges & ovens, other appliances, and lighting all are part of your energy use picture. The EnergyStar program is a good starting place, equipment rated with the "EnergyStar" sticker is more efficient than non-rated stuff.
You've come to the right place, use the "Find a Contractor" feature above to locate a pro in your area.0 -
Fuels
Your best bet in this case is probably oil. It has always cost less per BTU than propane, and it even costs less per BTU than natural gas at the moment.
I'm leery of using propane since it is heavier than air, and can build up on a floor or other low place, waiting for something to ignite it. This has resulted in some memorable explosions. In some areas it is now illegal to install propane-fired equipment in basements.
Modern oil-fired equipment burns with zero smoke and smell and similar efficiency to gas, when installed and tuned properly.
Consulting0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
