Thermostats
Dan Peel
Member Posts: 431
Try the Erie 201 for heat only or the 205 for heat cool. Uncomplicated two wire digital stat with battery backup. Enjoy......Dan
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=174&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Does anyone make a thermostat, that is easy, for seeing impaired, or someone that is confused? I have had good success with the t87 seeing impaired model, but some still get confused by the fan switch, and system switch.0 -
Try our new FocusPro...
Digital, non-programmable with the "big" display. The part number is TH5110D1022. This stat has just 4 buttons to use, always displays the room temperature, in really big numbers and the set point in slightly smaller numbers on the illuminated screen. These are available from any Honeywell distributor, if they don't have them in stock yet, they can order them. The Focus Pros and Vision Pros are readily available.0 -
Hate to piggy-back...
but how about for the completely blind? I have an elderly blind woman that is having trouble with her T87F. I once saw a thermostat that clicked as you turned the dial. Has anyone seen this?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
