Boiler feed pump
I'm involved in a project where I replaced a condensate pump with a boiler feed pump and created a water seal in the return piping. There are three main condensate return lines coming into the boiler room. Will air vents will have to be installed above the water seal level in these condensate return lines to allow air to vent from the system? Thanks.
Mike
