preset t/stat help
clammy
Member Posts: 3,212
Need a little help know i've seen them but can't seem to re call i'm lookin for a pre set t stat that is pre set to say 58 degrees 24 volt and also a out door sensor to turn the system on when temps hit forty .i thought accustat had units like what i'm thinking about for temp heat on jobs so the heat isn't at 90 thanks for any help i,ll figure some thing out but 2 heads are better then 1 thanks and peace clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
options
Accustat does have a preset thermostat. Buy the stat and the temp sensor you want. Cheaper way would be the construction stats but I've heard they aren't that accurate on temp. www.jacksonsystems.com
Any heat pump outdoor stat should work to pass a signal when the temp outside dropped below 40.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
