Adding a room to existing one pipe steam system
Dale
Dale Member Posts: 1,317
You can probably heat the reclaimed porch but what will sense the heat need? will you leave the door open to the rest of the house? If steam pipes are run out to the old porch will they need to be insluated to a higher degree than the basement? do you have room to extend to more than one rad. This will take some research.
