drip drip drip?
John_52
John_52 Member Posts: 1
Bought a 1950's era home in June. Turned the heat on ~ 10/1 and hear what sounds like dripping water in my ceiling.
How do I test if this is indeed a leaky system?
What are my options if it is? Can the pipes be replaced or am I facing a conversion to GFA?
HELP
  • Dale
    Dale Member Posts: 1,317
    Leaks are a pain
    Assuming the drip goes away except when the I assume, hot water, boiler is on You can shut off the makeup water inlet to the boiler, note boiler gauge pressure and if the gauge drops that is your source, have a pro trace the piping, a small leak can be fixed for a LOT less than a new system. I would also guess the homeowners warranty would cover the repair.
  • jackchips_2
    jackchips_2 Member Posts: 1,337
    Is it a drip
    or just expansion noise?
    A drip should show up on the ceiling right away.
