Digital Thermostat
Jeff_17
Member Posts: 99
WIll I get a more accurate house temp and a more efficient system if I use a digital thermostat rather than the old-fashioned round style. My round Honeywell is slightly out of callibration...and I have a millivolt steam system...GAS....
Any suggestions?
Any suggestions?
Try our new...
FocusPro 5000, it's a large screen, electronic. non-programmable stat. The part number is TH5110D1022 and it should be available from any Honeywell distributor or contractor. It's a brand new product, but they are in stock at the factory, so if your distributor or contractor has to order it, it IS available.
It will work with your millivolt system, and for your steam system, set the cycle rate to 1 cycle per hour. This is not a setback stat, setback is generally not recommended on one-pipe steam. There is no retail equivalent.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
