TwoThermostats
Paul_28
Member Posts: 113
I am going to constant circulation on a buderus system. I will need a second thermostat for the air conditioning. Any recommendations?
got to see
the new digital T-87. It has no mercury and lights up so you can see the setting and room temp. They also use power from the unit so no batterys to change. Looks better level but dosen't have to be. We have to make sure to wire them right. They come with a resistor for some aplications.0 -
Is that honeywell?
yep
t8775a1009 seems to work well and looks just like the t-87.0 -
Yes the # is t8775a 1009 and you need a sub base for cooling.0
