How do I bleed/purge my heating system?
Nron_9
Nron_9 Member Posts: 237
Please call a qualified person to help you before you damage the boiler or more importantly yourself or someone else
  • Aandrian
    Aandrian Member Posts: 1
    How do I bleed/purge my hot water heating system
    Hello,
    Last summer, my roommate had decided to disconect and replace 3 cast-iron heat radiators from the system. In doing so, I think she shut-off the water valve that feeds the tank. When winter came around, only half of the house heated up.
    I tried to bleed the system, by releasing the trapped air through the bleeder nozzles on each radiator (there are 12 radiators in my house), but I don't think there was enough water in the system to create enough preasure to circulate through the entire house.
    I thought about opening the cold water valve (to fill the tank), but each time I left it open for so long, the release valve, at the side of the burner, would blow, releasing all the hot water out.
    Help!!!
    Q-1: Should that cold water valve remain open
    Q-2: If I leave the cold water valve open, what will happen when the water tank gets full?
    Thanks for your help.
