Expansion Tanks
Paul_28
Member Posts: 113
How long do they last?
Exactly......
.....42 minutes.
Just kidding.
I don't think there is an answer to your question - alot would depend on the environment of the installation, the water quality, runtime of the system, and so on.
I have seen tanks last for 20+ years, and have seen them fail after just a few years. Biggest thing from a maintenance standpoint is to make sure the air charge is proper, if it's a diaphragm style tank. Air can migrate through the diaphragm at a rate of about 1 PSI per year. If it is a standard steel tank with no diaphragm, then you just need to make sure the tank does not become waterlogged.
Starch0 -
Down and Wet
By hanging them down and keeping the blader wet ,it will hold it's charge longer......0 -
