single-pipe steam radiator/is copper pipe ok?
rr
Member Posts: 3
Kind Helpers: I would like to use a length of copper to connect a floor valve to a single-pipe steam radiator. Is copper pipe strong enough to handle the pressure of a single-pipe steam radiator system? If not, what materials should I consider? Thanks for your advice.
I wouldn't use copper
The soldered joints can't handle the expansion and contraction, and they'll eventualy break.
Use black steel piping.All Steamed Up, Inc.
Consulting0 -
steamhead: Thanks for the quick response. What if the joints were made using compression fittings rather than solder? Would expansion-contraction no longer be a concern...or would it become an even bigger problem? (I'm still talking copper here, but what about other nonferrous metals, too?)rr0 -
20 yrs with copper pipe
I just tore out a whole single pipe steam system that included several 10' to 20' sections of 1" copper pipe. Never had a problem with it, including all the expansion and contraction.0 -
I have a whole single pipe steam system that includes several 10' to 20' sections of 1" copper pipe. Never had a problem with it, including all the expansion and contraction.0 -
Phred: How are the copper sections joined with the rest of the systemsolder, compression joints, lots of bubblegum?0 -
Bubblegum
worked for the first 10 years. Soldered to threaded fitting last 20 yrs.0
