HOT WATER HEATER, HEATING
tariq
Member Posts: 14
Is it permissible to use a regular 40 or 50 gallon domestic
water heater for a small heating load?
water heaters
It does work, but is controlled by local mechanical codes. You need a relief valve for a boiler, instead of the relief valve shipped with the unit. Most water heater manufactures, have units made for domestic water,and heating, called combi-cores.0
- 120 Geothermal
- 394 Solar
