Radiant manifolds
neuro
neuro Member Posts: 7
I am a DIY at the start of doing a radiant heating system looking for some feedback regarding manifolds Wisbro vs Rehau.Heat loss analysis has been done by both companies, I just want to know if there are any pros and cons from one to the other. Thanks for any help!
  • they both work
    and work well.
    However, rehau's has flow meters you don't need a $400 electronic tool to read. That's a big plus in my book, if you need visible flow metering, and not every job does. If you're going to have different sized loops the flow meters are especially good to have.
  • neuro
    Manifolds & tubing
    Hi Rob
    Thank you for your reply.I had to install tubing this weekend for basement as they want to pour cement Tues.A.M.
    The only tubing I could get on short notice was Wisbro.
    My question is? can I install a Rehau manifold using Wisbro tubing. Thank you
  • yes you can
    wirsbo compression fittings and rehau compression fittings both work with each other's tube. so use rehau manifolds and fittings with the wirsbo tube if you like and it'll work fine.
  • Boilerpro_3
    Boilerpro_3 Member Posts: 1,231
    My preference
    is for fully soldered or brazed manifolds with the Wirsbo Propress rings or Rehau's equivalent. No rubber gaskets, to leak no comperssin fittings to come lose.
    Boilerpro
  • Boilerpro_3
    My preference
    is for fully soldered or brazed manifolds with the Wirsbo ProPex rings or Rehau's equivalent brass. No rubber gaskets, to leak no compression fittings to come lose.
    Boilerpro
