Hydronic coil BTU ratings
Charles Brand
Member Posts: 3
We are working on a very large house which has a hydro air system. The hydronic coils do not have a plate which shows the BTU rating. Does anyone know where we can find a chart which would allow us to convert the dimensions of a hydronic coil into a BTU rating?
nope
However, knowing the cfm of the unit might help you out.0 -
Good Luck
I'm guessing you can't measure the cfm, gpm, and water/air delta T's.. Your local Heatcraft rep can probably take a pretty good guess at it.0
- 120 Geothermal
- 394 Solar
