Snowmelt Supply & Return Lines
Ken_19
Member Posts: 1
Greetings Guys,
Looking for suggestions on a lower cost(vs. eccoflex) for insulating snowmelt supply & return lines. What innovative ways and means have you found to do this?
Thanks Ken
Thanks Ken
Donkey Penis
You know what I mean... We just grab a box or two and walk each peice down the line. One guy feeding and three guys walking and you can insulate in a hurry.It's not as good as the commercial stuff, but it's a heck of a lot better than no insulation at all...Tape the joints with mil tape for integritiy.
A tip, if you will put a soldered cap over the end of the pipe you are insulating, the insulation JUMPS onto the pipe with a minimum of exertion. Otherwise, it snags, drags, rips and tears.
Also, use the stuff that comes with the talcum powder on it. It goes like glass....
ME
Urecon
Urecon offers a pre insulated round 4" solvent weld PVC pipe in 10 foot lengths. supply and return pipe can be run through this. I have not used it but it looks slick.
contact Derek at 780-985-36360
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
