Anybody know the bolt pattern for B&G PL 50
hr
Member Posts: 6,106
The PL 45 and 50 use a wider bolt pattern flange than the other PL series. My PL cut sheet doesn't seem to indicate the bolt center to center spacing? Thanks for any help :)
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
It takes the HV Flange
The HV flange is a little wider, I can fax you a spec tomorrow if needed. I also have been stocking the new isolation flanges which have the "dual" bolt pattern and can fit both the standard and HV flange configurations.
regards,
PR0 -
hv
hv0 -
Is it the same as
the Grundfos 43-75 flange with @ a 3-1/2" bolt spread center to center?
hot rod
That sounds accurate
But see if this helps
see pages 3 and 6 of this PDF file, I don't have the Grundfos B&G cross reference in front of me to verify.
Regards,
PR0
