zone valve
m dewolfe
m dewolfe Member Posts: 92
I you had to stock just one brand of zone valve for all of your instalations what brand would it be and why? My favorite would be taco gold series but I would like to hear some others......
  • bill_33
    bill_33 Member Posts: 1
    zone valves
    by far the best valve to stock is the honeywell v8043 series. easy to install and to troubleshoot. the motor,entire head and the internals can all be replaced easily.
  • K&M
    K&M Member Posts: 3
    Zone Valves
    I would agree with Bill on that too , the V8043 (Honeywell)zone valves are probably your best bet for ease of service , intallation . The entire power head is easily replaceable . One thought though , those screws that hold the motor in place are real real tiny , easily dropped into the most ungodly places.
  • Tom Simensen
    Tom Simensen Member Posts: 74
    The Taco ESP valve gets my vote. They are a compact state of the art valve with a good Cv rating. They are also very easy to wire and service. Best product to come around in a long time.
  • Glenn Harrison_2
    Glenn Harrison_2 Member Posts: 845
    Tom, just out of curiosity...
    What kind of luck are you having with the newer generation of the ESP valves?
    We used the first generation of ESP valves, and with all the problems there were with them, my company got away from them and won't touch them with a 10 foot poll. Due to this, I haven't had any experience with an ESP in two years.
  • Glenn Harrison_2
    I would also vote for the Honeywell
    In fact, that is all we install in zone valve jobs.
  • Weezbo
    Weezbo Member Posts: 6,231
    Taco . Esp . AI i Series s and i-Series r ....
    the taco valve body accepts the heads from the set point and the out door reset model....now if you been installing the taco esp and had a couple go "south" dash back over to the house and offer an Up grade ..:)as i do mostly new construction i literally have it Dictationed:)
  • Tom Simensen
    ESP
    Hey Glenn,
    I really didn't have many problems with the first generation. I have had no problems with the 02 since they came out the first of the year.
    Maybe I just don't use the quantity that you use, or got some different batches, but I can't compain about the few I've had to replace.
    I hope my luck holds out, because I'm really liking them.
    Tom
  • John Abbott
    John Abbott Member Posts: 361
    Zone valve
    Taco Gold: simple, reliable, proven track record.
    John
  • Jerry_7
    Jerry_7 Member Posts: 23
    circulator
    I put in circulators and flochecks. I would not take the job if they wanted to use zone valves.
  • Randy Tibbits
    Randy Tibbits Member Posts: 91
    I prefer the honeywell valve. I always reccomend when changing the valve assembly change the back plate as well.
  • Alan_6
    Alan_6 Member Posts: 87
    I vote for white rodgers, they can be more difficult to troubleshoot, but seem to last for a long time, and dont cause water hammer like the honeywell.
  • Glenn Harrison_2
    Thanks Tom.
    We had a almost 100% failure rate with the dozen or so we put in. We had one customer that we changed the heads twice and still had a problem, so they demanded (and rightly so) that we rip them out competely, and put in Honeywell's. It did turn out the combo of these valves and W.R. t-stats we liked to use apparently would cause electrical problems. The good news is we put a couple ESP's in the company presidents house, and they have worked flawlessly. Go figure.
