NATIONAL US RADIATOR BOILER
BPC
Member Posts: 1
NEED CAPACITY OF ABOVE BOILER FIRING AT 3.9 GPM
ANY HELP APPRECIATED
THANKS
BRIAN
THANKS
BRIAN
Brian,
What is the age of the boiler? If it is an older boiler, check the library section here on Dan's site. Go to the Beacon Boiler Book.
Good Luck
Dave
www.trainingontheroad.com0 -
is it
140,000 btu x 3.9gph= 546,000btuh if you use that nozzle. This is oil I guess..... 1 gallon #2 is around 140,000btu right. This should give a rough est.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 927 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
