wireless thermostats
bob_34
Member Posts: 40
has anyone come across a wireless thermostat ala wireless doorbells? seems like a simple idea/ simple technology for those add on zones with inconvenient thermostat wiring routes.
Previous thread
DATE: Sep 21, 2000
SUBJECT: Not running yet
I have four Genius systems out there in various stages of installation, but
none are started yet. I will keep you posted. If they would add a dry contact
at each output so you could run pumps instead of zone valves (Are you
listening, Jeff Weiderman?), I would sell 'em like candy. If they work well, it
will beat spending hours chasing thermostat wires, especially in renovations
even with the cost of the base unit ($500 list).
hb
DATE: Aug 08, 2001
SUBJECT: Please Remember
Whenever you have a wireless unit, you are transmitting a signal. This
requires electricity, usually in the form of a battery.
The HO needs to understand that battery maintenance is their responsibility.
Also, before installing any wireless device, check the unit's range and
frequency specifications. The higher the frequency (2.4Ghz) the greater the
issue with physical obstacles. Because this spectrum is close to physical light,
it has some of the characteristics of light. For example, like not being able to
shine through a wall. In this case walls made of certain materials.
Good luck, Phil.
DATE: Aug 08, 2001
SUBJECT: Danfoss has a nice
looking wireless setup. Haven't used one yet however.
hot rod
DATE: Aug 08, 2001
SUBJECT: Drayton
make some.
http://www.climate-eu.invensys.com/ICCEUServer/Family.ASP?FAMID=FAM312
Honeywell has...
the T8665A1002, a wireless, 7-day programmable digital stat. It works with the W8665A receiver unit, that is mounted in the mechanical space. Range is 200 feet, and they are available from any Honeywell distributor. Go to the www.honeywell.com/yourhome/ and enter those numbers for more info, or go to http;//hbctechlit.honeywell.com for tech sheets.0 -
after posting i did a google search for wireless thermostats and was surprised to find there are several models available. more surprising is after 25 years in the business i have never come across or heard of them before. thanks for the info.0
- 120 Geothermal
- 394 Solar
