furnace cleaning
Unknown
Member
Look at the picture at the bottom right side of this page.
http://www.cgfproducts.com/prod5frame.htm#01
Noel
Noel
furnace cleaning
Is there any way to clean the flue passages of a furnace properly? like an attachment that goes on the soot vac so you can snake it in and around the heat exchanger. I don't do a lot of furnaces but I am thinking of branching out and would love to do it properly.Any good suggestions will
help. Thanks.0 -
Supply house shoild be able to help you if you ask for a snorkle. There is 2 lenths I believe but the 6' should be all you need.0 -
Supply house should be able to help you if you ask for a snorkle. There are 2 lengths I believe but the 6' should be all you need. Noels picture is what they will give you.0 -
Hello BigEd, Just a note there are two diff sizes of hoses i have one of each some times its easyer to get the skinnyer one around instead of the fat one, if you have both you can fit your needs better.0 -
Pellet Stove Brush
Found this at Menards. Has a 2 -1/2 inch diameter brush with a hard nylon ball at the tip to guide it through elbows. Fiberglass rods are flexible enough to go through 90 degree elbows. Haven't used it to clean furnaces, but did use it to brush out the vent and combustion air pipe on my 90 percent gas furnace.0 -
cleaning heat exchangers
I took a piece of non metalic conduit and wrapped duct tape around it tell it fit tight into my vaccum hose cheap, quick, eazy and you can get it into almost any heat exchanger.alright for a farm boy0
