Teledyne Laars Endurance
Tony_8
Tony_8 Member Posts: 608
On the whole, I've had success with them. They have a 2:1 turndown and an anti-condensing valve and are pretty much the 86% efficiency they advertise all the time.
On install, the SS concentric vent is a PITA, but better than the Heatmaker's. It does limit installation location if you want to use it, and I would. The HX and flameholder doesn't like airborne lint, chemicals, etc.
The problem I've had the most is the circuit board. The only other problem I've had was the flow switch for the DHW, and what a B#%*&h to change !!!
Get a "Field Service Kit" from Laars, it's worth having on hand.
