metric piping connection
Bob Gagnon plumbing and heating
Member Posts: 1,373
can I tighten a 3/4" compression coupling onto a 22 mm pipe, without it leaking? it is just a little smaller than 3/4". Bob
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=331&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
conversion fittings?
I had the same idea. I am looking into using a european boiler in canada (i'm checking into regulatory issues). The boiler has 22mm fittings.
Shouldn't someone make conversion fittings for metric to imperial piping?
pasquale0 -
solar panels from the U.K.
are what I'm hooking up. I can't buy any conversion fittings from the local suppliers or the solar panel mfgr. The panel manufacturer told me to tighten the 3/4" down on the 22 mm pipe. or to use the 22 mm fittings supplied with the panels and sand down the 3/4" copper till it fits into the 22 mm compression fittings. with the anti-freeze in the system I am worried about leaks. Bob
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
I think I would use the 22 mm fitting's supplied and shave down the copper. If you use L-copper you shouldn't run into any issue with to thin a wall. I would just be concerned with trying to crank a 3/4 fitting on there...worried it would strip...just my 2 cent's..:)0
- 87K THE MAIN WALL
- 57 Biomass
- 115 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 983 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
