steam
Mellow_2
Member Posts: 204
Just some pics to show. We changed this steamer out the other day. This is half counter flow and half parallel flow one pipe dry return. Gas to oil in an apt. setting with an oil meter so they can split the oil bill. We must return to cover the pipes and do a second skim but they should be better off. nothing was working on the old unit. It just died in the summer....... so sad. Need to work on my computer skills so I will try some pics. P.S. how do you make the pics smaller and turned? AND the gray thing at the top of the photo is the gas meter.
Try These
My way is convoluted..... I use KeyView Pro to change the .jpeg files to bitmap (.bmp) files, then open the bitmaps in Paint (comes with Windows) to make the changes. Then back to KeyView to change the modified bitmaps to .jpg files again.
It works, but it's not the easiest way. I'm sure there are programs out there that will work directly with the .jpg files, but haven't looked too hard for them yet.
Note that I also shrunk the pics to 30% of their original size. This makes them fit into a browser window more easily, and also reduces download time. The last point is especially important to those of us who still don't have broadband Internet connections.
Nice job, by the way.All Steamed Up, Inc.
Consulting0 -
thanks I think I have it. cooool.............0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
