DESIGNER RADIATORS
Greg Webb
Member Posts: 1
Hello USA.
Here in the uk we mainly use hot water heating systems. I understand in the usa steam systems are used & our steel radiators if used will corrode. I manufacture a new range of radiators where the water only comes into contact with copper & brass. The unit is connected by standard threaded connections via valves. I read that a steam system needs steam traps can these be fitted in the pipework without the need to modify my unit. Please see the website www.jouleflow.com this explains the principle. Is there a market in the usa for this type of unit? I look forward to any help or comments.
Best regards,
Greg Webb.
Best regards,
Greg Webb.
Very cool Radiators!!
> Hello USA. Here in the uk we mainly use hot
> I look forward to any help or comments. Best
> regards, Greg Webb.
> regards, Greg Webb.
Thats thinking outside the box!
There is a group here on the Wall that feels that copper and steam shouldn't be mixed, Search the site on "copper returns" or "copper and steam" and you will find much discussion on this.
Traps can be piped in near the radiator and are normally found on the radiator on the outlet.
Generally you need larger inlet size for steam than water. I would definitely fit these to a steam boiler before I tried to sell them as steam radiators and see if they work and what the output is.
Regards
Robert
ME0 -
I like the low profile
of these rads. They can hide in a corner
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
