Chimney Relining Questions
Tom_22
Member Posts: 108
Do the newer more efficient boilers run better with a smaller chimney? I have seen this claim made by chimney liner manufacturers.
Is there a formula for calculating the optimum chimney size for a given boiler?
General rule of thumb for a BUDERUS boiler. Chimney size should be the same as the breech size of the boiler. This is refering to Buderus only - do not want to answer for the other manufactures. Suggest you call the manufacture of the equipment and inquire with them.
Thanks0 -
Liner capacity
There is a reference that specifies what the heating capacity of a liner is with respect to it's diameter, height and lateral run. Does anybody know where it is located on the web?
I also think that there are some other factors to be considered like how many 90 elbows there are and whether it's a ribbed (flexible) or smooth liner.0 -
TomBK..
See the thread below: Does an interior chimney need to be lined?.....Robert O'Connor/NJ0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
