taco i series mixing valve
m dewolfe
m dewolfe Member Posts: 92
Have many of you guys used the I series mixing valve from taco, I have a job I would love to try them on but my local supplyer is having a tough time with delivery and pricing. Seems like a good solution to the middle tier instalation with any pros or cons?
  • Weezbo
    Weezbo Member Posts: 6,231
    Took Fo evah to get them ....
    however lashed them right up. used a series s for the bypass at set point........used the other on a staple up with wirsbo thick plates....outdoor wwsd :) is working fine so far:) we use a lot of partial reset here in alaska with oil fired boilers....it gets fairly chilly here so...you neednt fret they doing the job:) been into the 20¡ãF's in the nights recently...winters on the way...
  • i series
    I just used the outdoor reset version. Found it to be very nice for a all in one control. Pricing was fair too. I don't know why it took so long to get. They are in stock at Taco and UPS-able via the reps.
    Gregg
