Forced Hot Air?
Boston Boiler
Member Posts: 70
What would be the top 10 size replacement belts for a forced hot air system that would be best stocked on your truck for an after hour no heat call? Maybe 10 is not even
close to enough? Take a good look at this authors name when
you answer and you can maybe save me the trouble of wiring
a box fan into someones high limit switch so they don't freeze this winter. Thanks..........ROOKIE
Adjustable belts
They aren't cheap, but I have something like this on my truck:
http://www.jasonindustrial.com/transmission_belts/vbelts.php
They make Acculink belts that you fit to the size you need for the job. They are listed in the current Johnstone Supply catalog.
Jeff
Thanks Jeff, a couple of "not too cheap" belts are better
than a ton of cheap not the right size ones........Rookie0 -
Belts
In general, I keep from 4L350 to 4L500 on board. This takes care of most of the old and new units. I do carry a Sid Harvey's universal for emergencies.0 -
Thanks guys0
- 120 Geothermal
- 169 Indoor-Air Quality
