Heating valve
Mr Kelly
Member Posts: 2
We have an issue with our plumber. We have installed an underground heating system, heat exchanger and geothermal heating system. However the system is missing valves that open and close the hot water to an individual underground pipe (for a particular room) i.e each room has a thermostat which should control a valve which opens or closes the under ground pipe to that room. Instead now the whole house is either on or off...very annoying.
None of these thermostats are installed. We are looking for a supplier who could supply these.
I have attached a picture which is in BMP format which you can open in paintbrush (you need to save to disk and open itto view it..sorry I dont know how to save a JPG)
Mr Kelly
Your drawing really dosn't help much as there are many companys that make that type of valve and you need the one that made for that manifold.
What seems to be the problem with the origianll installer ? Maybe we could help you with that situation andresolve the problem. Then he could return and fix the proplem.
If you really need to find the correct vavle you'll have to provide a manufacuters name or better yet a Photo.
Good Luck
Scott
hmmmm.... i agree. your picture is colourful though:)
look at danfoss valves on the internet see if one of them sorta fits the bill ...did our man take the valves off and discard them on the existing system?that did work in conjunction with the t stats?prior to the new zone?
Agreed the 'picture' is not very good. The problem is more complex than this. I looked at the Danfoss http://www.danfoss-randall.co.uk/Site/images_library/manifold.jpg
and this is the type of thing we have not the same...I'm not at home so I cant check the manufacturer but I will thanks so far.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
