Steam to Hot Water Conversion
Boston
Boston Member Posts: 71
We are moving a 1895 Victorian to a new site and want to add a garage under.
Problem is there are steam pipes in the way - one runs across the floor where we want the cars to go, some others are hanging down from the ceiling.
I am thinking if we convert to hot water we can have a lot more flexibility on how to pipe. Thoughts? If you tell me a good steam guy can keep the pipes out of the way, I am for keeping steam.
I have never seen a return run across the floor before. Is that common?
  • Dave Flood_3
    Dave Flood_3 Member Posts: 7
    Steam
    I'm sure there must be a reputable steam contractor in Boston. The pipe on the floor sounds like a wet return line. If it creates a problem for you, it may be possible to have a contractor eliminate the line and install a boiler feed pump or condensate pump.
    www.trainingontheroad.com
  • Dale
    Dale Member Posts: 1,317
    House move
    If you are moving an old house and cutting alot of the old steam piping IMHO this is the time to convert to hot water and give yourself the benefit of a fully condensing gas boiler and radiant basement and first floors. Since your new lower walls will be nicely insulated the heating system can match the actual heat loss. Perhaps none of the 100 year old steam pipes joints will crack but why risk it. And, theres nothing like a heated garage and basement floor.
  • lchmb
    lchmb Member Posts: 2,997
    just a thought
    I would get in touch with a good company who deal's in both steam and hydronic's and have them come in for a looksee. For the cost of a call they can give you all the answer's you need and help you get ready for whatever you decide to do...
    Steamhead Member Posts: 18,535
    A good steam guy
    really can reroute those pipes without screwing up the system. And you probably won't need a return pump either.
    Converting to hot water can be risky. Go to
    http://www.heatinghelp.com/newsletter.cfm?Id=22
    for a discussion of these risks. Then go to the Find a Professional page of this site- there are plenty of steam guys in the Boston area.
    I'd keep the steam.
    Consulting
