water washing
jaybee
Member Posts: 128
I have asked several people about this topic and i whould like to see what other think: Some say when u wash a boiler with water u run the risk of cracking the bolier.H ow could this be if u are using the water from the boiler itself or from hot water in the coil?
I have washed hundreds of boilers and no cracks yet. I usually use tap water. You can damage a chamber or target wall. If the boiler doesnt have a chamber then it is the best way to get the cast clean.0 -
Water washing
Some years ago, I went to class with Weil-McLain. They recommended their boilers be washed. Get temp. to above 160, and squirt it down. Been doing it for years with no problems.I use a garden type pressure sprayer. I do not use too much water.0 -
Washing Boilers
I don't know about you guys but mine would be a bear to get into the tub !
I had problems just getting the dog in the tub.
Scott
Washing
I got a good laugh out of that one! But nah, Just take it into the driveway and use your garden hose.0 -
Washing
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
