I can't find..........hb
Hey brother, would a two-stage heat/two-stage cool work?
If so check out Honeywells new TH8320U 1008 It's pretty slick!
your friend in the industry,
Alan R. Mercurio<BR><BR><a href="http://oiltechtalk.com">www.oiltechtalk.com</a>
  • heatboy
    heatboy Member Posts: 1,468
    a two stage heat, one stage cool with.............
    seperate 24 VAC circuits. I'm sure someone, i.e., Honeywell makes one, but I looked through my Johnstone book to no avail. Help?
    hb
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    Hi, HB!
    Alan beat me to it, and he's right. That stat can do up to 3 stage heat, 2 stage cool, plus a lot more. They're available from any Honeywell distributor. Part number is TH8320U1008, name is VisionPro 8000. Let me know what you think of it.
  • S Ebels
    S Ebels Member Posts: 2,322
    Series 8000 Stats
    Are the best thing since sliced bread. Once you've installed and programmed one you'll be hard pressed to use anything else.
  • heatboy
    I believe you, Steve, but.........
    as always, trying to find things you want, let alone on someone's shelf, is nearly impossible. I'm just going to split the therms.
    hb
  • BillW@honeywell
    HB...
    Drop me an email with your shipping address & I'll send you one for evaluation.
  • John MacGregor_3
    John MacGregor_3 Member Posts: 31
    TH8000
    Bill W @honeywell,
    I was just about ready, yesterday in fact, to install one of these wonders in my new home to replace the Bryant Evolution, but realized that there is no way to connect my humidifier to it. Or did I miss something in the wiring
    instructions? I would think any multipurpose modern t-stat would include a connection for a humidifier.
  • S Ebels
    Programming options
    vary with the particular stat but "briefly" they are
    # of stages,,,, 7 day programming,,,,system type, heat cool, heat pump, hot water etc.,,,, reversing valve operation,,, cycles per hour in heat and cool,,,, backlighting on/off/intermittent,,auto or manual changeover,,,,deadband from 2-9*,,,,display in F* or C*,,,Daylight savings time,,,Remote outdoor temp sensor,,, filter reminder run hours,,,, humdifier pad replacemnt reminder,,,U/V lamp reminder,,,Adaptive intelligent recovery,,, number of periods per day,,,compressor off time,,,adjustable high heat and low cooling temps for those folks who think the hihger you turn the stat the faster it works,,,,clock format 12or24 hr
    adjustable fan on time after call for heat and/or cool,,,,
    Various models have different capabilities. These are for the basic single stage heat/cool stat. They go up to 2 heat and 3 cool I think. There are alos some models that will run the humidifier and U/V lamp.
  • BillW@honeywell
    The PC8900 offers that option...
    and that's what I have in my own home. PC8900/W8900 is hard to beat, it's a 7 day EnergyStar programmable stat which also offers humidifier control, up to 9 remote temperature sensors, ventilation control, circulation control for the fan, automatic frost protection and a host of other features. The W8900 comes in 3 models, conventional, heat pump, and conventional with reheat for cooling applictions in high humidity areas. The new Vison Pro does have a model that includes a de-humidification control, it's the TH8321U1014. Thanks for your interest in our product. Check out http://hbctechlit.honeywell.com for spec sheets.
