zone valve wireing
jaybee
jaybee Member Posts: 128
I was just wondering if i had a flow cotrol that was stuck in open position and it was a emergency situation could i put in a zone valve if i didnt have a flow control.Also how would i wire it in the system? Lets see can it be wired like this : TRANS TO T-STAT OTHER END OF T-STAT TO ONE END OF THE ZONE VALVE MOTOR,OUT THE OTHER END OF MOTOR BACK TO THE OTHER SIDE OF THE TRANS.THEN, THE END SWITCH WIRED TO TT ON THE SWITCHING RELAY.Will that work just thinking of things that could happen. Im new bare with me!
  • Do you mean
    if a flow valve was stuck open ? You could cut in a zone valve , but when the system is drained down , it's much more easy and inexpensive to just change the flow valve . But you do have the wiring correct if you ever need to cut one in . Don't worry about being new , keep the questions coming .
