Hole in chimney
Paul_28
Member Posts: 113
I have a 3 inch hole in my chimney for the flue pipe from an old water heater, which I will be removing. The tile pipe extends about a foot in to the chimney. How can I close the hole? I though of using cement. Is there any other way?
pick up a cover
and then cement it in to place.0 -
cover
Do you mean cement in place with regular morter mix or with some type of caulk?0 -
Either will do
I use silicone mostly. WW
Couldn't they also just use mortar to fill the thimble without the cap (or if the thimble is in good shape just put a cap in the thimble if it fits tight).
I think the upshot is you need to fill it with masonry or metal but how you do that isn't all that critical.
Matt0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
