Monoflo Tee Question
John_34
Member Posts: 35
I have added 3 new radiators to my 2-pipe hot water system. Right now there are two monoflo tees (one on supply, one on return) feeding one radiator from the main pipes. Downstream on the main from these monoflo tees is where the 3 new rads are. The tees are 1-1/2 on 1-1/2 mains. My question is: Should these monoflo tees be replaced with standard tees? I'm afraid they won't allow enough flow downstream to feed the new rads in addition to the existing rads that are already downstream.
B&G says......
The cv rating for the second tee drops 36% and on and on..... You will need some pump sizing on this one. Suggest you contact B&G0
- 114 Geothermal
