Buderus Pics
dconnors
Member Posts: 215
As a member of the Buderus team, I want to congratulate you on a nice set of pics. Blue always looks good to me.
Buderus Pics
Here are some shots of our new Buderus boiler. Thanks to Homestead Fuel for the installation and The Wall for helping me in the decision.0 -
looks good
Looks good but i'm not one for direct vent or the z flex vent kit and i wouldn't want that steel pipe on my boiler water feed not to mention there's no low water cut off i know i'm being a nita greta heating system that should give you many years of faithful service but please remenber a oil burner should be service every year and listen to oyur oil it looks like he's lookin out for you peace clammy picker sorry but all aside congrates onR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Low Water Cutoff
Since we did get our CO I assume the low water cutoff is not a code requirement for hot water boilers (I assume steam is different story). Is this something that we should have had put on our system?
John0 -
Hey Doc Heat
That's a beautiful boiler!0 -
beautiful
i must agree.0 -
lwco
In some states it is code if the baseboard is below the boiler .Personally i install them in every boiler i install it's a great insurance that you don't dry fire where it's residental or commerical where it's manadatory with manual high temp limit .for what it costs look at the whole picture what did the whole system cost ?1 or 2 hundred for a lwco is pretty cheap just my opion peace clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
I agree Clammy
You can't make z-flex look good, ever. You level the boiler and put a torpedo on every pipe and the z-flex turns out looking like a dryer vent hose hooked to the boiler. The black iron pipe after the water feed will give you problems down the road by plugging up. Why on earth would they have done that??0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
