sizing pipe
Bob_36
Bob_36 Member Posts: 83
I know that 1/2" pipe will supply up to 15k at a 20deg. delta T. I want to know if it makes a differance if I hook up ci rads. The rads will supply from 6k to 11k btu/h. Each will be a home run back to a manifold. Will I get enough flow through the rads or should I use 3/4" instead. Thanks for any input anyone may have.
