Name that radiator? Radiator Mystery.
Joe_30
Joe_30 Member Posts: 85
Name that radiator? Radiator mystery. Who made it? What is heat output?
We got three of these for $10.00 each in a tear-down of a late 1950's or early 60's upper scale rambler in Minneapolis. They were fully recessed in walls. Each "section' is cast as a unit of six tubes wide. The face you see is, therefore, two such sections plus two end-cap sections. Then the back side is the same. It's sort of a two-tube radiator. An end-cap section is also pictured. This radiator is 27" high and 22" wide. It's considerably heavier than a normal three-tube radiator. Thank you, Joe.
