Vento indirect radiators
norfitz
Member Posts: 55
A San Francisco bldg has banks of Vento c.i. indirect rads in 9-section blocks stacked 3 blocks high, enclosed in ducting with huge squirrel cage blowers below. Old data shows 16 sq. ft. per section, but I believe that's a gravity airflow rating. As a tall convector cabinet uses more steam than a short one, it follows that these use far more steam when used as fancoils than their ratings suggest. Anyone know how to quantify this load? I've stumped a surprising sampling of well-known names with this one.
Thanks much,
Bruce Tompkins,
Power Boiler Sales
Thanks much,
Bruce Tompkins,
Power Boiler Sales
How about
Steam fan coil load in Pounds of Steam per Hour = CFM X Delta T of air (in degrees F.) divided by 800.
Can you work with that?Retired and loving it.0 -
Hi Dan. Are you saying I don't factor in the Vento's EDR ratings at all?
Bruce0 -
As you said
the rating you have is for gravity air flow. That formula will give you a way of checking the output for the purpose of boiler sizing when there's a fan blowing across the heaters.Retired and loving it.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
