Questions on using Hydronics Pro Design Studio
Ted_9
Member Posts: 1,718
When calcing the heat loss in a room, there are 3 "Exposed Floors" choices.
None
Framed
Slab-on-grad
The room in question is over an unheated basement. When I choose "none", the heat loss looks ok. When I select framed, the heat loss is high. I use a 50 degree temp for the basement. Ive also activated the basement program.
I'm trying to get this heat loss done today and I need some help.
None
Framed
Slab-on-grad
Heres an update. When I select framed I use 50 degrees for temp and Instead of putting in zero for the insulation, I figured that the wood would be some sort of factor so I put I an R2. I t seems a bit normal more.
Any input would be greatly appriciated.
Patriot Heating & Cooling, Inc.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
