buderus install
clammy
Member Posts: 3,191
Just finished this one g115 size 34 no flow valves went with all taco ifc 007 pumps ,webstone isolation valves on all ,priority dmw provided by taco pmp controller and a buderus indirect tank .I also elimanated the 2 pipe oil system and put a tiger loop in to elimanated re pumping fuel to the tank long distance went through a pump seal on return restriction and to long for a single pipe so i felt i did the right thing .I also threw in a domestic expansion tank with a shut off .For the most put it took 1 mech and 1 helper 2 days removal and clean up but i must return to install a fresh air duct this home is very tight and has always had combustion air issues now they,ll finally be resolved peace clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
