Oil Delay Test
Rookie_2
Rookie_2 Member Posts: 2
What would be the easiest most accurate way to test a oil delay valve??
Thank You ROOK
  • Dingo
    Dingo Member Posts: 38
    Just guessing here..
    but I would think a pump pressure tester and a stopwatch is where I would start.
    FWIW
    Dingo
  • Weezbo
    Weezbo Member Posts: 6,232
    disconnect its line from the gun put a clear tube.....
    over the flare an into a container...push the button .if you dont get fuel it isnt working:) or you might be out of oil! "depending on the lagg in the primary relay is the sight of oil":) Yoda
  • Biged
    Biged Member Posts: 117
    Oil valve test
    to check the oil valve disconnect the wire from the control then use a ohms meter and measure the resistnce between the top and bottom terminals, it should be between 350ohms and 550ohms. If it is not then its junk.
  • Rookie_2
    Thank You.
