DWH Tank
Paul_28
Member Posts: 113
My indirect water tank has a Gal/Min rating of 16 and a head of 4. I am planning to use the Taco 0010IFC pump. Is that acceptable?
pump sizing
Assuming the right numbers, the 010 is the pump to use. A 007 will give you the numbers but will be maxed out at that flow rate. The 010 is the next pump up the chart that will give you flow and GPM you need.
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
