primary/secondary piping
John G
Member Posts: 4
We have a radiant project with 4 zones.all zones total apprx. 25,000 ft/ of pex. we want to install 3 dunkirk 200k 90+ boilers in a primary/secondary piping scheme,looking for a diagram on piping or recommendations where we can view the correct piping scheme. and a place to find the pump sizing for boilers and loops. each zone is different lengths,two are apprx. 5k one is 8k and last is 6500 apprx. A Tekmar boiler controller is going to be used. There will be no indirect w/h.Any other piping ideas are welcome.
Primary/Secondary piping need help!
need help on designing a primary/secondary piping scheme for (3) Dunkirk boilers 90+ for a radiant heat project, we want to pipe all 3 together and run 4 seperate zones, we have another thread on this posted 8/22 also, there will be no indirect hot water utilized.0 -
Sizing
Was there a heatloss done and what kind of flow rates are you looking at?
S Davis
Apex Radiant Heating0 -
525k is the heat loss, flow rates are in the office, i can give those tomorrow, thanks for your reply. John0 -
We still need more info...
How many loops for each zone, heat loss, max. individual loop length, etc... anything else you can think of.
Here are some pics of a job I did last fall they might be worth more words than I could ever post here.
Floyd0 -
Primary/secondary piping
check out www.buderus.net. we not only have the boilers but the diagrams as well.0 -
Consider
investing $20. When you have it in your head, you own it.
Primary Secondary Pumping Made Easy!Retired and loving it.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
