Heat Loss
Bill_31
Member Posts: 6
Here we go again... My plumbing manager insists that it is more important to measure existing radiation when installing a replacement hot water boiler. I am of the school that you should complete a manual J on the house. Your thoughts?
Thank you.
Thank you.
You're both right!
A heat loss will tell you what is TRULY needed. An EDR will tell you what's there. Interpolate between the two and with some form of reset or water temperature control device you can both be right!0 -
You're both right!
But you're a lot "righter" than he is (:-o)
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
