7184u honeywell
tommyoil
Member Posts: 612
Can someone explain to me what the difference is(performance wise) in the various motor off delay timings on this control? And what would be the advantage of longer,say 4 min. as opposed to a 2 min. setting on the dip switches. I have been setting them at 2 min when I use them. Should I be? Are they there for different applications? I'm not sure I'm doing the right thing here. I love this control.
I would say that 2 minutes is more than adequate
with a chimney or direct vent, less chamber. You should increase it if you have a chamber, poor draft, etc. Powerventers and such should probably use their own timers and match it to them, the longer the better generally, but every application has its querks.
For more info go here:
http://hbctechlit.honeywell.com/Main.cfm?CFID=1618450&CFTOKEN=69929852
For our book on primaries go here:
http://www.firedragonent.com/Books.htm0 -
why
Why would I have to increase the time w/ a chamber(which most of the stuff I work on all have). What is the rationale there. I could understand with lousy draft but what effect does a chamber have on the big picture? Does it tend to hold the heat longer?0 -
The possibility of more latent heat! An old
trick is to put a thermocouple into the chassis on shutdown and observe, the Carlin U multimeter will do that!0 -
Got it!
Thanks for the lesson(again). I'll add it to the list of things I have learned from you over the years.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
