Boiler Insulation
Zorian Pinsky
Member Posts: 21
Please assist with source of data on amount (thickness) of boiler insulation, as well as the material type and the suppliers. I am considering replacing asbestos insulation on my 70+ years old Weil-McLain steam boiler. The asbestos will be removed by a certified contractor.
Thank you.
Zorian
Thank you.
Zorian
Don't stop there
Replace that 70 year old boiler also, its done it job.
Scott
Boiler Insulation
There are few reasons, as you can understand, I delay that:
1) Too expensive, to justify for next 4-6 years;
2) Was told that the boiler would/should last...
Zorian0 -
its a roll of the dice
" Do you feel lucky, well do ya ? "
ITs not a 45 magnum but its old boiler that in my opinion has gone way beyond its life expectancy. I always consul my customers to make the change on oyur time because the boiler will pick New Years Eve.
AT the effecincy of that boiler I don't see where any insualtion is going to make a big differnce.
Others may tell you different.
Good Luck
Scott
insulag
I agree w' the other fellas on replacing the museum piece that is now heating your home. Should you opt to get more life outta this boiler, you could try insulating w' insulag and use 'smooth kote' on top of that. Maybe you should read some of the posts regarding CO. They may be fitting for what you're trying to do.0 -
Insulag
Ernie,
What is CO? If you mean CO gas, I do have a detector in the basement.0 -
Why would you waste money
on a 70 yr old boiler? Save and get it all replaced. I'm sure your contractor would charge less if the job was a removal of the boiler. No need to do an intense cleaning on a boiler thats being pulled out.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
